Please add an option to add hidden field to the widget as in the Form Builder. I know that there is a Do Not Show in Results option for the Calculations, and I would like to have a default filed that is hidden too
Hi there, @user28229 and welcome aboard ![]()
Thanks for sharing your thoughts with us!
Could you please describe your use case in more detail? What would you like to achieve with the Hidden field used in the calculator?
This info would help us understand your idea better ![]()
