Add Faire for pulling reviews
It would be nice to pull in reviews from Faire like you can for Etsy. Thank you! :blush:
Hi there, @Tara_Petrilli :waving_hand:
Thanks for sharing your idea! If more users upvote this request, we might consider it in the future :slightly_smiling_face:
In the meantime, you can manually add reviews from Faire using our All-in-One Reviews app:
Hi, Max
I know it was a long shot as there might not be many folks out there connected to Faire.
I do have an All-in-One Review widget set up which I’m in the process of adding the reviews manually.
Thanks,
Yes, I am afraid the chances of the Faire source to be released in the near future are not so high. So, the manual review addition is the only solution for now.
However, we’ll have this idea in mind and see for more votes and feedback from others :slightly_smiling_face:
