Add Countdown timer to popup
thanks for this community
i hope to add countdown to app popup when we are using a discount
Thank you for your kind comment, @Youssef1! I’m happy you love our community :slight_smile:
I’d love to say that you CAN add our Countdown Timer widget to our Popup widget, this is the outcome of such an integration (the templates are fully customizable, of course):
Screenshot 11-21-2022 13.15.17
You can find out how to do so in this article: HTML block in Popup widget - Elfsight Help Center
If any questions come up, feel free to place them here :slight_smile:
