Simple, area for Fax number. ![]()
Hi there @Matthew_McGahren ![]()
Nice idea, thanks for sharing! Let’s see if it catches on with the community ![]()
However, I am happy to say that our devs came up with a custom solution for you:
const FAX_TEXT = 'FAX: ';
const FAX_NUMBER = '777-777-888';
const LISTEN_TYPES = {
one: {
validate: (node) => !!node,
all: {
validate: (node) => node?.length > 0,
function listenStep(args) {
args.node = args.select(args.selector, args.root);
if (!args.validate(args.node)) {
args.step++;
if (args.step < args.limit)
setTimeout(() => {
listenStep(args);
}, args.delay);
else args.reject();
} else {
args.resolve(args.node);
async function asyncListenFor(selector, type = 'one', customArgs = {}) {
const args = {
root: document,
node: undefined,
selector,
delay: 100,
limit: 50,
step: 0,
select: LISTEN_TYPES[type].select,
validate: LISTEN_TYPES[type].validate,
...customArgs,
if (type === 'one' || type === 'all') {
return new Promise((resolve, reject) => {
listenStep({ ...args, resolve, reject });
asyncListenFor('.elfsight-app-a87e610e-ca5b-4490-a11e-cfcba2c90f44 > div').then(
(widgetContainer) => {
const container = widgetContainer.querySelector(
'[class*="multi-column-layout__Column-sc"]'
console.log(container);
if (container && container.children.length >= 2) {
const secondChild = container.children[1];
const clonedChild = secondChild.cloneNode(true);
console.log(clonedChild);
const faxText = clonedChild.querySelector(
'[class*="contacts-item__UnderlineWrapper-sc"]'
console.log(faxText);
faxText.textContent = `${FAX_TEXT}${FAX_NUMBER}`;
faxText.setAttribute('href', `fax:${FAX_NUMBER}`);
if (container.children.length >= 3) {
container.insertBefore(clonedChild, container.children[2]);
} else {
container.appendChild(clonedChild);
This code should be added to the Custom JS field on the Style tab of your widget’s setting
This code adds a line for the fax.
FAX_TEXT is a text between the icon and the number. If you don’t need it, just leave empty quotes, (" ‘’)
FAX_NUMBER is the actual fax number.
Check it out and let me know if you like the result ![]()
Amazing, Thank you!
