Add captcha
Captcha would prevent bots from spamming the widget
Hi there, @Hello61 :wave:
I like this idea, thanks for sharing! Let’s see if it gets traction with the community :slightly_smiling_face:
Our AI Chatbot just got spammed by bots, it would be great to get a CAPTCHA to filter these out :folded_hands:
Thank you for sharing your use case, @user4768!
We’ll try to think about in our future updates if more users support this idea :folded_hands:t2:
Hi @Hello61,
Before I vote for your suggestion, can you provide specific examples where your AI Chatbot has been spammed? So far, ours is performing great.
Useful Tip: Please keep in mind that you can always implement anti-spam measures to your entire site via Cloudflare and/or Google API. This is our method and a more efficient approach.
For details, simply perform a Google search using the following string: “how to implement recaptcha to chatbot widgets” and you’ll get several specific methods to make it happen.
Yes, having an integrated recaptcha within AI Chatbot would be nice, but I don’t consider the feature a top priority at this time.
I hope this helps both you and the community.
Cheerio!
Friends, our devs found a custom solution that blocks bots from using your AI Chatbot. This article explains how you can do this :wink: - How to stop bot spam in your AI Chatbot
Thank you, @Max. Good to know!
