Add audio tracks to products and let users download tracks after buying products
Adding Digital products to E-commerce Stores.
HI there, @Ray_Giangiordano :waving_hand:
Could you please describe your use case in more detail? What do you mean under the digital products? What features/settings should be available in this app? Do you have an example of a similar existing app?
Absolutely, with Wix I have trouble making bundles I think we should make an app for attaching audio files to clothing. For example, you buy the shirt and get your audio downloads with it. I was wanting to do this with my new single I think it could work with multiple platforms.
Each product should have its own audio file, which should become available for download once the payment is completed, am I right?
Yes sir, and maybe more than one file attachments included if added
Got it, thanks for sharing the details!
The functionality you’ve described is quite complex and isn’t a standard feature for most widgets, since it requires the integration with the payment process and external storages for audio files.
So, we don’t have a solution for this case at the moment and can’t give any promises. However, we’ll keep this idea on the Wishlist and if any news comes up, we’ll update you here :slightly_smiling_face:
Found this link it is something similar to what we were talking about. My idea was to add PDF Files and 2 Audio Files. There’s only 20mb hours and I should do more.
Got it, thank you so much for sharing this example with us :slightly_smiling_face:
