Accessibility Improvement
When navigating with the keyboard, the calendar event cards aren’t providing any visual identification on what element is selected or navigated to. Creates a blind navigation.
To be more in line with our accessibility efforts it would be great to see changes made to the code so that the event card elements are keyboard selectable.
Hi there, @Adrian_Bernal :waving_hand:
Thanks for flagging this up!
I’ll discuss with the devs if it’s possible to apply a quick fix and will let you know once I have any news :slightly_smiling_face:
While our devs are working on a global solution, we’ve applied a local fix to your widgets. Please check them out and let me know if everything is fine :slightly_smiling_face:
