Accessibility icon change color
  • Issue description:
    Hi there,
I do not understand how to change the color of the icon of this app: Accessibility
How can I do this?
Thank you in advance!
Hey there, @user527 :waving_hand:
Please add this code to the Custom CSS field on the Settings tab of your widget’s settings and let me know if it helped :wink:
#icon-color {
  fill: red
Can I make it a custom color using code?
Yep, custom colors are also supported :slightly_smiling_face:
I tried this color #521248 but it does not work.
I’ve used this color code, and it worked fine for me:
