A way to translate documents?
Hello - we are working towards adding the Translate widget to our LMS via Google Tag Manager however, I still need to find a way to translate documents since the widget won’t do it. When a user clicks on a document from the LMS or one of our SCORM packaged courses, it auto downloads. Does anyone have a solution or creative way to give the user a way to translate these docs, without having to use Google translate, etc? We have global, non-English speaking users and it would be great to have a widget in a doc maybe? Not sure what functionality the pdf embed widget here has. Thank you!
Hi there, @Jill_Sharlock :wave:
Could you please send me a link to the page where these docs are placed? I’ll be happy to check things for you :slightly_smiling_face:
If the special access is needed to see the page with the docs, please send me the credentials in a private message. Just click on my profile image and select Message:
I used Jotforms earlier today, and they have a translator option, but you have to double check and add some items manually before publishing.
Hi there, @SouthPark :wave:
Do I understand right that the Website Translator widget doesn’t work with the Jotforms you’re using on your website? If this is the case, please send me a link to the page where you have the Website Translator widget and Jotform.
However, if I misunderstood you, please describe your use case in more detail :slightly_smiling_face:
