I like it centered on left side but it is not working on some pages, and in left corner with 80 vertical offset is not quite enough on mobile, any way I can increase that vertical offset but remain to work as a percentage from base. thanks.
Hi there @Rev_Devan ![]()
I’d love to help you with the Popup customizations!
For me to check everything and provide CSS codes, could you please send me links illustrating the little flaws? For example, you mentioned that sometimes alignment to the left works, and sometimes not. Please send two website links showcasing both – it will be so helpful ![]()
Also, please clarify a bit more about the offset:
- Do you want the vertical offset to be a percentage of the height of the widget?
- How much larger do you want the offset to be?
- Do you want this changed on mobile only, or on the PC version as well?
Looking forward to work with you on this one ![]()
