Zoom-in transition between slides
I was looking to change the transition to a zoom-in & out effect. Please refer to the link below for the effect on their slider in the home page.
It seems like upon changing the slides, the current slide is zoomed in while the incoming slide is zoomed out. I hope this makes sense. Thank you!
Welcome to the Community, @JW_TA :wave:
I really like your suggestion, thanks for sharing! Let’s see what others think about this transition effect :wink:
