Wild Apricot integration
My organization uses Wild Apricot. There is little flexibility. I’ve been using some of the tools here to create enhancements to the site (AI chat, reviews). It’d be great to enhance some of the other features for better UX: calendar, subscriptions, email newsletters. I’ve been building them myself and would love just to get them here.
Hi there, @Karen7 :waving_hand:
Thanks for sharing your idea!
Do I get it right that you’d like to have a WildApricot integration in the AI Chatbot and All-in-One Reviews app? If so, could you please describe how this integration would help with the automatization of the processes in these widgets?
I’m already using chatbot and the reviews app and they’re wonderful. Wild Apricot has API’s that I use to build better UX than what Wild Apricot has built in.
So, your idea is to create a separate widget based on the Wild Appricot integration, right? If so, could you please describe what features should be available in this app and how you’re going to use it?
One idea is the event calendar. Events are set up in Wild Apricot but they don’t look as nice as the Event Catalog in your catalog.
Got it, thanks!
We can’t promise that a WildApricot integration will be added to the Event Calendar. However, if more users support this idea, we might think it over in the future :slightly_smiling_face:
