Widget to Showcase "Featured-On" Podcasts
A widget that allows you to plug in links to different shows you’ve spoken on/been a guest on.
Similarly, could be good for featured-in articles for blogs/articles.
Hi there, and welcome to the Community, @Andrew_Chambers :waving_hand:
I see you’ve already found our Podcast Player app and added your playlist there. Do i get it right that you’d like to exclude podcasts without your participation?
If so, I am glad to say that it’s possible to do this:
  1. Open your feed link in the browser:
  1. Right click the feed and Save it as a Text file:
  1. Open the Text file with the feed and remove the podcast items without your participation. For example:
  1. Click File → Save As:
  1. Choose All Files from the “Save as type” dropdown and add the .xml extension to the File name:
  1. Upload the feed to your own or any external server.
Give it a try and let me know if it helped :wink:
