WebMCP (Web Model Context Protocol)
Hi Elfsight team,
I’m a long-time Elfsight user and affiliate partner. I’m writing to ask
whether WebMCP support is on your roadmap, and to make a formal feature
request if it isn’t yet.
WebMCP (Web Model Context Protocol) is a new W3C standard developed by
Google and Microsoft that allows AI agents — Gemini Agent, ChatGPT
Operator, Copilot Actions — to discover and execute actions on web pages
directly from the browser, without DOM scraping. It’s currently in Origin
Trial in Chrome 149, with full Chrome + Edge support expected in H2 2026.
The specific issue with Elfsight widgets
Elfsight widgets render inside cross-origin iframes. This creates two
blockers for WebMCP:
  1. The Declarative API (`toolname` / `tooldescription` attributes on
    ``) can’t be applied because we don’t have access to the HTML
    inside the Elfsight iframe.
  2. The browser blocks JavaScript access to cross-origin iframes, so
    the Imperative API (`document.modelContext.registerTool()`) can’t
    reach the widget from the parent page either.
What would make it work
The fix has two parts, both on Elfsight’s side:
  1. Add `allow=“tools”` to the iframe element Elfsight injects. This
    enables the WebMCP permission policy for cross-origin iframes
    (per the WebMCP spec: WebMCP  |  AI in Chrome  |  Chrome for Developers ).
  2. Implement WebMCP tool registration inside the widget’s own JavaScript,
    so the Contact Form widget registers itself as an executable tool
    when the page loads.
With these two changes, an Elfsight Contact Form widget would be
discoverable and executable by AI agents — making Elfsight the first
third-party widget platform with native WebMCP support. That’s a
meaningful competitive differentiator as agent-driven web traffic grows.
The use case
A user’s AI assistant visits a client’s website, finds the Elfsight
Contact Form, and fills it out autonomously to request a quote — without
the user having to open a browser. This is already technically possible
for native HTML forms; Elfsight widgets are currently the gap.
Is this on your roadmap? I’d love to know the timeline if so, or to
add it to your Wishlist as a formal feature request.
Thanks for building a great product.
Best regards,
Hello there, @Francisco_Javier_Ma1 :waving_hand:
A huge thank you for such a detailed explanation!
Adding the MCP feature is a great idea, but, unfortunately, we haven’t considered it yet. We’ll keep this idea in mind and if it gains more votes, we’ll try to think it over down the line :slightly_smiling_face:
Are you considering adding support for WebMCP to your platform? Adding allow="tools" to the iframe would be sufficient. However, Elfsight doesn’t support it yet
Hi @Francisco_Javier_Ma1 :waving_hand:
Unfortunately, this feature isn’t on our roadmap yet, but if anything changes, we’ll promptly update you in this thread :slightly_smiling_face:
