The weather widget isn’t appearing on our intranet site currently. We’re nowhere near the view threshold
Hi there and welcome to the Community, @Kevin_Luong ![]()
Just to clarify, did the widget not show up right after installation, or did it appear initially but then disappear?
Also, could you please share a screenshot of your Dev Console? It could help us figure out what’s going on ![]()
@Max we’ve had the widget for a while now, but noticed today it’s not appearing. We have it embedded through a widget using Staffbase as the vendor
Got it, thanks!
Do you have any browser extensions/VPN/antivirus enabled? If so, please try to disable them and let me know if the widget appeared.
