Using Elfsight's widgets into Coda
Hi there…
I’m trying to use my widgets into Coda’s page but I always receive :slight_smile:
So…
I’m asking myself if there is some particular thing to do or if maybe widgets are blocked…
If someone know something would be great to share it.
Thanks
Hi @Ankharys :wave:
Could you please send me a direct link to the webpage where you’re trying to install the widget?
