Trendyol Review
www.trendyol.com Review
Hi there @Can_Yurekli :wave:
A million thanks for adding your idea to our Wishlist!
If this source becomes popular, we’ll try to add it to our widget. We’ll keep you abreast of any progress here :slightly_smiling_face:
Attracting comments from this trendyol.com marketplace with 160 Million+ visitors worldwide
Hi there :wave:
Thank you for sharing your feedback with us!
You see, since we get a lot of requests and the process of adding new reviews sources is not easy, we have to be picky and choose the most popular requests first.
If Trendyol source gets more votes, we’ll try to take it under consideration. We’ll keep you in the loop here :slightly_smiling_face:
As a workaround, you can manually add the reviews from Trendyol using the Custom Source option in our All-in-One Reviews app. Feel free to check it out:
