Toast POS Website
  • Issue description: My website is through my restaurants Toast POS. They. have the option to enter custom code in a block on your site. As soon as I past the elfsight script into the custom code field..it throws an error and makes me reload the site or undo recent changes. Was hoping someone might know a way around this. I added html.. im a restaurant manager not a coder. Thanks!
  • Elfsight Widget /\* Removes default margins so the widget fits cleanly edge-to-edge \*/ html, body { margin: 0; padding: 0; width: 100%; height: 100%; overflow: hidden; }
  • Link to the page with the widget in question: mtshasta1939.com
Hi @Michael_Flynn and welcome to the community!
It sounds like you are doing things correctly.
Full disclosure: I’m not familiar with Toast POS, so I asked AI. Here is the reply I got:
It specifically mentions “HTML snippet or code” so it should be possible. Is this how you are entering the Elfsight code? If not, try it. If it is how you’ve been doing it, verify that you are not inserting the widget script inside another script. Scripts begin with a <script> tag and end with </script>. You have to ensure that you’re not dragging the Elfsight code between those two tags.
Give this a try and let us know if it get things working for you.
Hi there, @Michael_Flynn and welcome to the Community :waving_hand:
The widget is getting cropped because it’s installed in an iframe. I am not sure if it’s possible to install the widget avoiding iframes in this case, but our devs will be happy to check things for you.
For this, please send us the installation request and our support agents will pass it to the dev team :slightly_smiling_face:
