I want to synch TeamUp and Elfsight. I love how easy TeamUp is, but I hate the visuals.
I use TeamUp because you can have events belonging to different categories that appear as sub-calendars. Then you can filter to only see the events of that category. I also love that a large team (of over 200) can put their events in the calendar easily and they can only modify their own events, which makes it easy to not accidentally delete other people’s stuff.
If I synch TeamUp with Google Calendar for example, I lose the ability to have one event belonging to different categories. Elfsight has categories for filtering so I want that. Is that currently possible, or should I move this to the Wishlist?
Hi there, @Vera_Franco ![]()
Thank you so much for such a detailed comment!
Unfortunately, it’s impossible to sync our Event Calendar widget with TeamUp now. I am really sorry!
I’ve moved your idea to the Wishlist and if it gets more votes, we’ll try to think it over down the line ![]()
