Submit and navigation localization
Hi,
I am new here and testing the form builder widget. At the moment, I’d say it’s almost ok.
What I need is to be able to localize in other languages the submit button and navigation with multi steps forms (next, back). The only localization option is for error messages and some form elements.
Thank you for considering adding this feature because your widget can’t be used with non english websites.
Cheers,
Cris
Happy to see you in our Community! Welcome @Christophe_Capdeviel :wave:
You can change the text of all the mentioned buttons in the Buttons section on the Build Form tab:
Hi,
Yes this is what I realized!! Sorry for the topic, so.
Cheers,
No problem! You are always welcome :wink:
