Issue description: I asked Squarespace why there was an excessive amount of padding below my footer and they were able to figure out that it’s because of the Store Locator code I have at the bottom of all of my pages. Any chance this is an easy fix I can make with CSS or JS code?
Link to the page with the widget in question: The website isn’t published yet, but I attached some photos to help show the issue. This is what the footer looks like without the code being added to the page:
And this is what it looks like when it’s added:
Hi there, @Lily_Gamble1 ![]()
Extra padding on Squarespace websites is usually caused by Squarespace’s Fluid Engine editor. To fix it, please add the script below to the Custom CSS field on the Style tab of your widget’s settings
.global-styles,
.fluid-engine:has([class*='elfsight-app']) {
grid-template-rows: unset !important;
I added the code, and unfortunately it impacted the spacing on the entire page the widget was added to. I’ve deleted the extra code for now and am tabling the issue while I work on other parts of the website.
Got you! To find the optimal solution, we’ll need to check the widget on the website.
Could you please either publish your website and share a link or add a widget to a test page and share a link to the test page? I’ll be happy to check things ![]()
