(Squarespace) Add a Load more button to Bandsintown Block
To add a load more button to Bandsintown Block, like this.
#1. First, use this code to Custom CSS box.
If code doesn’t work, you can comment below, message or email me.
div.sqs-tourdates__item {
  display: none;
.sqs-tourdates__item.active {
  display: block;
.load-more-button {
  display: block;
  text-align: center;
  margin: 20px auto;
#2. Use this code to Code Injection > Footer.
  $(document).ready(function() {
  var $items = $('.sqs-tourdates__item');
  var itemsPerLoad = 5;
  var visibleItems = itemsPerLoad;
  $items.slice(0, itemsPerLoad).addClass('active');
  $('.sqs-tourdates').after('<a href="#" class="load-more-button btn btn--border theme-btn--primary-inverse sqs-button-element--secondary">Load More</a>');
  $('.load-more-button').on('click', function(e) {
    e.preventDefault();
    $items.slice(visibleItems, visibleItems + itemsPerLoad).addClass('active');
    visibleItems += itemsPerLoad;
    if (visibleItems >= $items.length) {
      $(this).hide();
#3. Result
