I’ve been working on getting our website approved for the Google Ad Grants program for nonprofits, and one of the biggest issues I’m running into is page speed. Google has you test the site with https://pagespeed.web.dev/, and the Events Calendar page is causing the most problems.
I’ve already tried disabling lazy loading, but it’s still struggling with load times. I know I’ve made quite a few customizations to the calendar, but if there’s anything that can be optimized internally to improve performance, I’d really appreciate it. Otherwise, I may not be able to continue using it if it prevents us from meeting Google’s requirements.
Hi @Rev_Devan, you probably already know this, but just in case…
disabling lazy loading only helps if the widget displays above the fold. If it’s below the fold, it will have the opposite effect.
One thing you may want to try until staff returns on Monday is the thread from last month that talked about a substitute script for the widget. But again, this only helps if the content is below the fold. Here’s a link to my experience using the alternate script. You can read through the posts if interested. There’s also something you can try which works regardless of where the widget appears on the page: How to reduce page loading time
We’ve checked your site and noticed that the widgets are placed in the initial viewport. This prevents the lazy loading feature from working properly, as the widget loads immediately when someone opens the page.
To fix this, you can move the widget code lower on the page. Right now, it’s in the body, and we recommend moving it lower to the footer.
I totally get you! The solution I’ve shared won’t slow down the widget loading speed and should improve the website performance. Could you please try it out?
I’ve just double-checked your website and noticed that the installation codes of some widgets are used without a lazy load attribute - data-elfsight-app-lazy.
Please add this attribute to the 2nd line of the installation codes (right after the widget ID) and let me know if it helped. Here is how the installation code should look:
