We already provide very detailed schema for our products. When enabling schema for our Google reviews your are generating additional product schema which is completely wrong and basic. Give the option to turn off generated product information and only generate the reviews schema.
eg. Our schema provides the correct Brand, yours puts the product title in the brand
our schema provides the correct product images, yours just adds our company logo.
Our schema provides the correct sku and MPN, yours appears to generate a random number that means nothing.
I want the option to generate ONLY review schema and not have you trying to guess what my product schema should be. This only confuses Google.
I checked your website and see that you’re currently using the Organization markup type, while our widget uses Product markup.
We intentionally use Product markup because it’s the markup type supported for displaying this kind of information in Google search result snippets. Other markup types wouldn’t provide the same result there.
If Product markup doesn’t suit your needs, you can easily disable it on the Settings tab:
If you’d like to have an option to choose the markup type directly in the widget settings, we already have a Wishlist request for this feature. Feel free to upvote it to show your interest: Enable businesses to set the Product markup types
I use the organisation type on my home page, on my product pages I have my own product schema. Why would anybody use a product type on the home page as it is not a product.
I am not asking to be able to change the schema type, I just want to be able to stop you from generating your own product schema such as brand, image, sku, mpn, etc which is all incorrect. I just want the reviews schema.
Turning off Schema in the settings, I assume, turns it all off.
This is a reviews widget. Stop trying to be a product schema widget. you know nothing about my products. I just want you to add the reviews to schema (aggregateRating, ratingValue and reviewCount) and maybe some individual reviews.
Apologies for misunderstanding and thanks for clarification!
You’re right, if the Schema option is disabled, the rich snippet won’t show up either. However, I totally get that you’d like to keep the rich snippet and use your own markup instead — this could be a nice solution.
I’ve moved your suggestion back to the Wishlist and we’ll try to think about this improvement in the future updates.
