Resizing for calculator
So ideally you can use the calculator within a header or on a banner rather than it being sized size. Maybe itll go hand in hand with multi-page calc
Hi there, @Ryan_Kirby :waving_hand:
Thanks for sharing your thoughts!
Could you please share how you envision the Calculator added to the header? The header height is quite small, so the widget elements will be poorly visible there.
Regarding the widget installation to the banner, could you please specify you’d like to use and the page, where it’s installed?
I think it would only work with a multi-page calc so you could have a centred question or two per page then affectively it would use the space were the image is on the right have side of my screenshot to allow quick quotes above the fold
Got it, thanks!
You’re right — using the multistep layout would make the Calculator in the header look much cleaner. Once this feature is released, you’ll be able to set it up just like you suggested :slightly_smiling_face:
