Opening hours Appointment Booking
Hi there
On Friday, April 3, and Monday, April 6, we have special opening hours due to Easter. The restaurant is scheduled to be open from 8:00 a.m. to 5:00 p.m., but table reservations should only be accepted until 3:00 p.m. Currently, tables can be reserved until 4:45 p.m. How can I adjust this?
https://dash.elfsight.com/widget/05e04d83-360f-4c25-86a6-e61821d7bddd
Thank you
Dominik
Hello there, @Dominik1 :waving_hand:
Just to clarify, what should be the last available slot on these days (2:45 or 3:00 p.m)?
Hi Max
Last slot should be 3:00pm.
Got it, thanks!
Your request is with our devs now. I’ll report back once the solution is ready :wink:
Thank you very much!:blush:
Hi @Dominik1 :waving_hand:
We’ve adjusted your script. Please check your widget and let me know if it’s working fine :wink:
It works perfectly. Thank you very much!:star_struck:
It’s my pleasure :wink:
