I’m having trouble with figuring out the proper calculations to determine membership rate in my calculator. Can you help?
Hi there, @user32053 ![]()
Could you please describe how the membership rate should be counted in your use case? We’ll be happy to help you with the formula creation ![]()
Thank you for the quick response! I need to be able to click on each membership category (base rate) and a household income option to get the membership rate. See attached screenshot.
Sorry for being not clear enough!
To help you with the formula, we need to know how the Membership Rate should be counted based on the chosen Membership Type and Household income.
For example, could you please share what Membership Rate should be if Membership Type is Family and the Household income is $30,000 - 39,000? Also, it would be really helpful if you could explain how you got this result ![]()
Hey Max! We figured that portion out on our end. I appreciate your help.
Awesome, you’re very welcome ![]()
