I created a simple Slider widget and embedded it into my SquareSpace sight. Mostly it works just fine, but there’s a stray snippet of code at the top I can’t get right of:
Note that I use Squarespace’s “Basic” plan, so per Elfsight’s instructions I’ve embedded the widget’s code using Markdown as opposed to a JavaScript code block (which is only available on more expensive Squarespace plans. I mention this in case it might help explain what’s going on, though according to Elfsight’s installation instructions it should work.
Any ideas? Thanks in advance.
