Multiple Announcement Bars on same site breaks floating top display
I had two different announcement bars included on my site. Within the announcement bar configuration I had one bar set for directory A, and one set for directory B. Different messages for two different sections of the site. Both set for floating top. Both code snippets installed one after the other just above the closing head tag. This causes one or the other of the bars to intermittently display over the page rather than above the page.
So more than one code snippet on the same site is not feasible? This prevents using different announcements in different parts of a site. And it prevents scheduling a series of announcements to be show in sequence such as one to display from now until the 15th of the month, and a second to display from the 16th to the 20th. (without having to manually install the snippets one a at time.)
Is this a bug? Or is this not an intended use? Thanks for your feedback.
Hi there, @James_Cole :waving_hand:
Could you please send me a link to the page where your Announcement Bar widgets are installed? I’ll gladly look into this for you :slightly_smiling_face:
