I would like to embed a link for visitors to see our class schedule (available on Mindbody) directly on our website without having to leave for the less user-friendly generic log-in page.
Hi there, @Sam_Arnold and welcome to the Community ![]()
Thanks for adding your idea to the Wishlist!
Please let me ask some questions to better understand your use case ![]()
You’d like to add a link to your class schedule on Mindbody and it should be pulled to the widget, right?
Do you want just to show the schedule or let users sign up to these classes through the widget?
Could you please also clarify what you mean under this?
Yes - I can’t seem to figure out how to integrate a live visible class schedule (this is housed on Mindbody) that also allows visitors to log into Mindbody and schedule a class directly through the widget.
Does that make sense? Thanks so much!
Your visitors should be able to submit new classes directly through the Mindbody integration in your widget, right?
So, they’ll create new classes, set the date/time and add them to your schedule, is everything correct?
