Logo Showcase Is Horrible
  • Issue description:
I removed the logos but kept the captions in the logo showcase, yet now nothing appears except the logos from the original template. The captions are missing completely. This widget is extremely frustrating, and no one has been able to resolve the issue for over a week.
Hi there, @user25363 :waving_hand:
Apologies for the long wait!
I see that my colleague Danis has already reached to you in a support ticket. Here’ what he mentioned:
Our Logo Showcase widget is designed specifically to display logos together with their captions. This means that at least one logo needs to be added to the widget for the related caption to appear. Since there are currently no logos added, the widget has no logo items to display, so the captions are not shown either. Once you add your logos back to the widget, the captions will appear below them according to your current settings.
If you would like to display text-only content without logos, the Logo Showcase widget may not be the best fit for this use case. In that case, you may want to consider using another app, such as Testimonials Slider, which is better suited for displaying text-based content.
If you have any further questions, feel free to contact Danis. He’ll be happy to help :wink:
