Leads from Elfsight Form Not Appearing in Squarespace Contacts
Hi All - I connected my elsight form to Squarespace and leads are coming through via email notifications, however, they are not appearing as contacts within my Contacts section of Squarespace.
Any ideas? Thanks!
Hi there, @Lauren_Kirchberger :wave:
I am really sorry about the issue!
Do I understand right that you’ve connected the Contacts section on your website through the Zapier integration and you don’t see your submissions there?
Hi Max - that is correct. I also reached out to Zapier on this issue and they said that API feature is not available yet. If you can confirm whether that is right or wrong, that would be super helpful!
Also, does Elfsight have the ability for me to connect with my Google Drive? So any file attachments I receive through a form submit automatically get sent to a location on my Google Drive?
Thanks for your help,
Lauren
@Lauren_Kirchberger I believe it should work.
Could you check this article to ensure all the steps are followed correctly?
If everything seems right, but the issue is still there, please send me a screencast video of what you did. That would be super helpful!
As for sending the files to Google Drive, I see that this option is available on Zapier, so it should work :slightly_smiling_face:
