Issue with reply to 1st comment
Hello! If a user writes a comment and I reply to it, I can only reply to the next reply from the user if I click the “reply” button on the very first comment! If I want to do this on the reply button on the third comment, the comment will not be sent!
Hi there, @miko_zsolt_official :waving_hand:
I apologize for this inconvenience!
Could you please share a link to the page, where your widget is installed and record a video screencast of the issue? I’ll be happy to look into this :slightly_smiling_face:
I’ll show you in the control panel! I experience this with every installed version! Link: Sodrás
You’re right, it seems to be a global issue in the widget. Thank you so much for the feedback!
I’ve forwarded the issue to the devs and will update you once it’s fixed :slightly_smiling_face:
We’ve applied a local fix to all your Comments widgets. It means that all existing Comments widgets should be working fine now, but if you create a new widget, the issue will be replicated there.
Our devs are currently working on the global solution and I’ll update you once it’s released :slightly_smiling_face:
Thank you very much for the bug fix. :slightly_smiling_face:
You’re most welcome!
In the meantime, we’d like to invite you to participate in our new contest, where you can win a 3-month extension for your subscription - March Contest: Create a Dating Profile for Elfsight Widget and Win 3 Months FREE! :wrapped_gift:
Unfortunately, there is another error, as you can see in the video!
Thank you so much for sharing a screencast of the new issue!
I’ve passed it on to the devs and will update you once it’s fixed :slightly_smiling_face:
How are you progressing with this bug fix? :slightly_smiling_face:
I deeply apologize for the long wait!
I’ve requested an update from the devs and will immediately inform you as soon as I have more news.
Thank you, I’m waiting! :slightly_smiling_face:
