Issue with Logo Showcase height on Weebly
I am having difficulties getting the custom CSS to comply, using the code:
.eapp-logo-showcase-logo-inner {
height: 100px;
Does not work. Any other fixes?
Hi there, @Abigail2 and welcome to the Community :waving_hand:
Please try to use this CSS code instead and let me know if it helped:
.eapp-logo-showcase-carousel-inner {
  height: 300px;
Hi @Max , it did not work.
It’s on the footer of this website: https://www.quadcityarts.com/
It’s been built on Weebly if that makes a difference.
Thank you for your help!
Thanks for sharing a link!
The issue appeared because of the conflict with your website styles. The widget container inherited min-height: 100%; style from a different element on your website:
We’ve fixed this issue using this code in the Custom CSS field on the Settings tab of your widget’s settings:
.es-widget-background-wrapper {
    min-height: auto !important;
I’ve also noticed that you’ve additionally pasted the previous CSS code next to the widget’s installation code and the code is displayed on your website right now:
CSS codes should be added to the Custom CSS field of your widget’s settings. So, you just need to remove this code snippet from your website and you’ll be fine :wink:
I was adding the code everywhere! Hah!!!
You’re brilliant @Max , it worked!
No sweat!
If anything else comes up, I’ll be more than happy to help :wink:
