@Max, can you please clarify about the reset password bit? Reset the account password as well as in the widget, or widget only? Also, since I did not set this up initially, what about the IMAP/POP3 port… enter it as :### after the mail server or skip it entirely?
EDIT: I should clarify. Everything looks successful from the submitters POV, it’s failing the ‘Email Sender Settings’ configurator test. I think this has never worked for us. When it was originally setup, it was configured with my email address in the Notify Me field. When the tech setting it up saw the Success message after a test form submission, they assumed it was okay and moved on.
When I mentioned password resets, I was referring to Elfsight account passwords (for example, when users forget their account password and need to restore access). It doesn’t apply to widget settings or form-related passwords.
If your settings look correct but the connection still doesn’t work, could you please open the browser Dev Console, click Save and Test connection, and share a screenshot of the error from the Console tab?
This will help us better understand what might be causing the issue and investigate further
I see now what happened when the Form Builder was setup. The person originally configuring this saw the success message and assumed all was okay. I received the notification email but did not notice that the ‘From’ address was notifications @ elfsight.com and also assumed all was okay. See a pattern here?
I just tried reentering the sender info and know it is correct. I reentered it again (since opening DevTools clears the form) and hit ‘Save and Test Connection’ but it once again showed the Failed to connect message. Console shows no errors.
I guess I could live with the notification emails coming from Elfsight rather than our own domain since this is installed on one of our own sites, but it would be nice to get this right in case we ever get requested to install something similar on a customer site.
I’ll take a closer look and see if I can spot anything that might be causing the issue.
Please send them over in a personal message rather than posting them here, just to keep your email settings secure. I’ll be happy to investigate it further
Hello again @Max ! I solved the issue shortly after I emailed you. Since I don’t deal with the server side of the business often, I thought I’d double-check everything. We rent server blocks at several data centers so we don’t have to maintain them ourselves. Besides the config info I sent you, I noticed a note regarding the DNS cluster we have configured. It contained the mailserver name that was in the screenshot I sent you AWA the default. We have never used the default anywhere but just to leave no stone unturned, I thought I’d give it a try. And… Eureka, it worked! Now I have to get with the server folks to find out why.
I may have spoken too soon. The form is set to submit to my email address on our server + Bcc to a gmail account. The form notification email came through to our own domain okay, but I received a mail delivery error from Gmail. They need to have the sending mailserver (Elfsight) entered in our domain via either SPF or DKIM. To do so, I need to know Elfsight’s mail server name (this would be the same as ‘SMTP Host’ asked for in the ‘Add Email Sender’ dialog, except from your side). I’m guessing this would be different from forms.elfsight.com? Just let me know… via email if that’s more appropriate for you.
