Issue with Email Sender option in AI Chatbot
Thank you for adding that feature. I just tested everything, and it’s working perfectly.
The only thing missing is an option to set the From address /sender name for chat transcript notifications. Right now, they’re come from something like notifications@mydomain.com instead of using the actual sender name.
This is quite important because having the correct sender name and frm address can help improve email deliverability and reduce the chances of emails going to spam
Hi there, @Justworks :waving_hand:
I’ve just checked the Email Sender feature in my test widget and it uses the email address (without notification part) I’ve added during setup (Email Address and Username fields):
Do I get it right that you’ve added an email without notification part and after saving the sender, the email sender format was automatically changed?
