Hi, any ideas why this only works when I apply it in the widget, but when I save it and go to edit again, despite the code still being there, the text is not centered any more?
Hi there, @user16052 ![]()
I’ve checked your widget and see that you’ve missed a dot at the beginning of the code:
Please add a dot and the code will work fine:
Nope. Still comes back to the left after I publish and come back… Also I removed the dot to try and see if it worked, the dot was there before.
Ah, I see the issue now!
I’ve forwarded to the devs and will update you once I have their response ![]()
The issue has been fixed! Please check it out and let me know if everything is fine now ![]()
Seems to be good now, thank you so much!
No sweat ![]()
