Issue description: I’m trying to create a final expense calculator but I can’t get the sums of the male and female to calculate correct
Hi there, @Latasha_Nichols ![]()
I’ve checked your account and couldn’t find a Calculator widget that meets this idea. However, I’ve noticed that you’ve deleted this widget:
Is it a calculator you were referring to? If so, could you please share an example of the incorrect calculation and provide a correct result? I’ll be happy to look into this ![]()
