I previously submitted a suggestion to add a toggle (ON/OFF) switch to each AI Chatbot Agent Skill contained in the configurator. So far, no updates.
Until the toggle switches are incorporated into the configurator, can you kindly provide a mechanism for disabling the “Collect Contacts” skill? I can delete it, but that will require recreating it (a lot of info to add) if our team decides to use it again.
