Help with Event calendar
If your Elfsight widget displays a white background initially but then appears correctly when you load more content on your Wix site, it’s likely due to the way Wix handles page loading with AJAX, where only the initially visible content loads first, potentially causing the widget to render with a default background color before its full styling is loaded; once you scroll and trigger the “load more” functionality, the widget fully renders with the correct design.
Hi there, @Sarah_Piel :wave:
I see that my colleague Renata has already contacted you in a support ticket. As she mentioned, this may happen because of the widget’s background settings.
Please follow the steps suggested by Renata and let her know if it helped :slightly_smiling_face:
