I want a frame around a popup window, and are looking for a CSS who can make that. In forehand thank you ![]()
Hey there, @Paracord_no and welcome aboard ![]()
This code will do the trick:
.es-widget-background-container {
border: 2px solid #3a86ff;
Please add it to the Custom CSS section on the Settings tab of your widget’s settings and let me know how it worked ![]()
It works fine, Thanks! is it poosible too get rounded corners as well?
Hi @Paracord_no ![]()
You can change the border radius of the popup container using this CSS code:
.es-banner-container {
border-radius: 5px;
To apply the same radius to your custom border, please add this line to your first code: border-radius: 5px!important;
Check it out and let me know if you like the result ![]()
Great! thank you
It’s my pleasure ![]()
