Fine Horizontal Lines Inside AI Chatbox
On occasion, our visitors see one (1) to several fine lines inside the chatbox after the chatbot replies. Eventually, the fine line(s) disappear. Any guesses as to what is causing this? See below.
This issue may appear because of the CSS codes used in the widget. Our devs will investigate it and I’ll report back as soon as I have any news :slightly_smiling_face:
Unfortunately, we couldn’t reproduce the issue you’ve encountered. Could you please specify the device, where this issue occured?
Also, just to make sure I understand correctly — does the screenshot show your message being turned into that line, or did that line appear automatically right after the assistant sent a message, even if you didn’t type anything?
Hey, Max. Honestly, the blue lines haven’t appeared in several days. Previously, they appeared automatically right after the assistant sent a message. So, for now, I’ll continue to monitor this. If it happens again, I’ll dig a bit deeper before reaching out to you. Thank you so much for your time and dedication.
