Ah, I am sorry! Now, everything should be working fine.
HI Max, the codes aren’t working for me on the calendar app. Can you look at it? https://7aca92f699884c47a02771cf63f5291c.elf.site
Thanks,
Pam
Hi there @user13078 ![]()
I’ve shared your request with the devs. Once done, I’ll report back ![]()
We’ve hidden UTC by adding the script below to the Custom JS field on the Settings tab of your widget’s settings:
const LISTEN_TYPES = {
one: {
validate: (node) => !!node,
all: {
validate: (node) => node?.length > 0,
function listenStep(args) {
args.node = args.select(args.selector, args.root);
if (!args.validate(args.node)) {
args.step++;
if (args.step < args.limit)
setTimeout(() => {
listenStep(args);
}, args.delay);
else args.reject();
} else {
args.resolve(args.node);
async function asyncListenFor(selector, type = 'one', customArgs = {}) {
const args = {
root: document,
node: undefined,
selector,
delay: 100,
limit: 50,
step: 0,
select: LISTEN_TYPES[type].select,
validate: LISTEN_TYPES[type].validate,
...customArgs,
if (type === 'one' || type === 'all') {
return new Promise((resolve, reject) => {
listenStep({ ...args, resolve, reject });
const removeUTC = (selector) => {
asyncListenFor(selector, 'all').then((badges) => {
badges.forEach((badge) => {
const badgeText = badge.textContent;
badge.textContent = badgeText.replace(/\bUTC-\S*\b/g, '').trim();
removeUTC('.eapp-events-calendar-time-time');
asyncListenFor(
'#eapps-events-calendar-7aca92f6-9988-4c47-a027-71cf63f5291c'
).then((container) => {
setTimeout(function () {
removeUTC('.fc-event-time');
container.addEventListener('click', () => {
}, 10);
}, 10);
Please check your website and let me know if everything is fine now ![]()
