Double click on event in Calender
Is there a possibility to double click on the event in the calander to make changes (while in the edit version)?
Hi @user2979 :wave:
Do I understand correctly that you want to double-click on the event right in the calendar table so that you wouldn’t have to find the needed event in the list?
If I misunderstood you, please describe your use case in more detail :slightly_smiling_face:
Yes, that’s what I mean
Unfortunately, there is no such an option in our app. I am really sorry!
I’ve moved your suggestion to the Wishlist, and we’ll try to consider it in our future updates :slightly_smiling_face:
Just in case, I’d like to remind you that recently we’ve added a Search option to make it easier to find events in the list:
image image
Thank you for your response.
The search option is a good alternative.
No sweat :wink:
