Daily Bible Verses
To put on website as daily encouragement
Hi there, @user4617 and welcome to the Community :waving_hand:
Thanks a bunch for sharing your idea!
Would you like to manually choose which verses should be featured on the website, or you’d like them to be randomly picked? What design do you envision for showing the Bible verses: floating notification panel, embedded banner, or something else?
