Custom autoplay option
Hi there! I want to use the same testimonials widget (Google Reviews) in multiple places on my site, but sometimes I want it to autoplay, and sometimes I don’t. Is there an attribute I can add to the embed script to be able to control autoplay on each instance of the Google Reviews widget? Perhaps something like what I demonstrated in my screenshot?
Link to a page in staging, with the Google Reviews widget:
Hi there and welcome to the Community, @Jon_Reese :waving_hand:
I’d like to mention that you can manually enable/disable the Autoplay option right in the widget’s settings:
Or would you like the autoplay to be automatically enabled/disabled on your website? If this is the case, please describe the condition when the autoplay should be enabled/disabled :slightly_smiling_face:
Hi there,
@Jon_Reese as I understand it, you want to use the same widget once with and once without autoplay. I don’t think that’s possible.
You could duplicate the widget and disable the autoplay function for that one.
