CSS for making Portfolio Tag menu full color
At the moment the portfolio tag menu is a dull grey colour. I’m using emojis in the tags, so I won’t the emojis to be full color. How do I change the color and darkness of the tag category menu at top?
Hi there, @Sal :waving_hand:
Currently, the category tabs are dull if they are not selected and you’d like to make them full color even if they weren’t selected. Is everything correct?
Yes, spot on! I want all them all to be full color. Ideally we could have them as buttons and change the button colors too…. but as a quick fix, I’ll settle for full.
This code should help:
.eapp-portfolio-project-list-categories-item {
  color: rgb(17, 17, 17);
Please add it to the Custom CSS field on the Style tab of your widget’s settings and let me know if it helped :slightly_smiling_face:
Wooohooo, that worked. Thank you sooooo much :folded_hands:
It’s my pleasure!
In the meantime, we’d like to invite you to participate in our new contest, where you can win a 3-month extension for your subscription - April Contest: What’s Your Top Widget Feature? Tell us and win 3 MONTHS FREE!🎁
