Hi Elfsight team! ![]()
I’m currently working with the comment widget, and I’d like to know if there’s a way to dynamically customize the JavaScript behavior based on the current URL.
More specifically:
- Each of my pages includes a dynamic
IDparameter in the URL (e.g.?id_property=12345), which identifies a unique listing. - I would like the comments to be associated only with that ID, so each page has its own thread.
- I need to know if there’s a way to bind the comment thread to that
id_propertyvalue in the URL, either by injecting custom JavaScript or configuring something within the widget settings.
Is there any API, JS callback, or attribute I can use to override or define the content ID or URL the widget uses to determine the comment thread?
Let me know if that’s possible or if there’s a recommended workaround.
Thanks in advance!
Best,
Martin
