In the blog on a mobile I would like to have a colour picker for the category drop down please. At the moment you can only have it as white.
Hi there, @Elle_Pinkard ![]()
Great idea, we’ll try to think about it in the future updates! In the meantime, you can change the color of the dropdown on mobile using this code in the Custom CSS field on the Settings tab of your widget’s settings:
@media (max-width: 500px) {
[class*="Dropdown__DropdownContainer-sc"]:not(.es-category-list-item) {
background-color: #f3e8ff !important;
.es-category-list-item {
background-color: transparent !important;
Fab, thanks thanks Max ![]()
