Change position to away from images and make bolder
How can I make the up and down arrows on the THUMBNAILS bolder and away from the photos so it is easily seen as it hardly shows up
Hi there, @user35204 :waving_hand:
I’ve checked your widget and see that you’re using the Grid layout. Do I get it right that you’d like to customize these arrows in the Thumbnails layout?
Hi Max
Firstly - I love your apps !
I changed the layout which looks a whole lot better and suits the page - so this is no longer a problem – thank you !
I have switched to the GRID view.**
https://www.rosewoodfurniture.co.uk/rosewood-furniture-colours3.htm
I do have a whole load of questions as below request 729977
Great, thanks for the update!
Yep, our Support Team received your support ticket and our support agent will reach out to you as soon as possible :slightly_smiling_face:
